Forums › Forums › RC6 With Dashcam & ThirdEYE › RC6 blue led on controller blinking rapidly after yellow wire grounded
  • RC6 blue led on controller blinking rapidly after yellow wire grounded
    Posted by Frank on 2026-11-04 at 23:53
    As per title, all connections are ok and checked. Software has been updated. Recording does not follow the on off switching anymore. Even with yellow wire connected to ground, rear camera stays warm for extended period
    Frank replied 2 weeks, 1 day ago 4 Members · 12 Replies
  • 12 Replies
    2026-11-05 at 00:04
    Hi Frank,
    The yellow wire should not be connected to the ground.
    The yellow wire must be connected to a switched power source—in other words, a wire that receives power when the ignition is turned on and loses power when the ignition is turned off.
    • Frank
      2026-11-05 at 01:21
      Hi Hans,
      Let me explain: the yellow wire is connected to a switch. This switch is connected one side to the battery (direct) and the other side to ground. So I would expect that when the yellow wire get’s the battery tension, the unit switches on and when the yellow wire is connected to ground, the unit switches off. What I see now is the following: switch is on battery tension: unit switches on but recording does strange things: recording not starting, random recording, etc. When switch is on ground position: blue led on controller is blinking rapidly. The power supply of the unit (red wire) is connected to the same battery.
  • Martin
    2026-11-05 at 21:49
    Hi Frank, I’m a little confused by some things you say, but mostly, your use of the word “grounded”. I take it that you are connecting the yellow wire to a separate switch that you have installed yourself, rather than connecting to a ‘switched live’ somewhere in your bike’s wiring harness?
    If so, there is no need for anything to be “grounded”, which in technical terms means the same as ‘earthed’. The yellow wire is simply a signal carrier to let the main unit know that it needs to turn on.
    So, in your case, you have one wire coming directly from the battery to your switch. I assume that this wire is connected to the Positive (+) terminal on the battery? The yellow wire needs to be connected to the other side of your switch. So, when you turn your switch ‘ON’, power goes from the battery, through your switch, then down the yellow wire into the main unit.
    Remember, this yellow wire is simply carrying a very low power signal to let the unit know that it needs to turn on. It is not powering the unit. But there is no need for anything to be “grounded”, so that is what is confusing me from what you have posted.
    When you turn your switch ‘OFF’, it interrupts this low power signal and so the main unit turns off. I hope this helps?
    When the rear unit stays hot it is because it is running and recording constantly. This, again, suggests that your switch is not interrupting the power signal from your battery’s Positive (+) terminal to the yellow wire.
    For your problem of erratic recording, “unit switches on but recording does strange things…”, how often do these things happen when the system is connected to your phone via WiFi and when it is not?
    • Frank
      2026-11-06 at 04:24
      Ground means – pole of the battery
    2026-11-05 at 23:17
    Hi Frank,
    Grounding the yellow wire serves no purpose. In fact, it could even cause strange issues, as an unwanted leakage current might begin to flow through the ground connection.
    If you do want to use a switch, ensure that in one position it connects the yellow wire to a power source, and in the other position, it disconnects it from the power source—meaning it should not be connected to the ground, either.
    By the way, I’m curious: what is your reason for using a switch?
    • Frank
      2026-11-06 at 04:12
      Hi Hans,
      The reason for using a switch is because my bike is a BMW K1600GTL. If the ignition is on, the bikes wifi takes over. The switch allowed me to power the RC6 and use the app to change settings. Since the day I received the system, connecting the RC6 to the app is a nightmare. On another note, I did a tour with the bike through the French Alpes and most of the video is corrupt, this triggered the investigation.
      • Frank
        2026-11-06 at 04:23
        Update:
        Status today:
        -Yellow wire is connected to switch and switches between battery tension and open
        -Switching the system on does not start automatic recording
        -When the system starts , no leds turn on on the front camera
        -Firmware reflashed
        -Memory card replaced
        -Manual start of recording works, video ok
        -Switching the yellow wire to off position (open) triggers the rapid blinking of the blue led
        -New: disconnecting the rear camera connector stops the blue led rapid blinking
        -I am out of ideas ….
        Best regards, Frank
        • This reply was modified 2 weeks, 5 days ago by  Frank.
    2026-11-06 at 23:11
    Hi Frank,
    You can configure the RC6 so that its Wi-Fi turns off automatically after a set amount of time. This eliminates any interference with your BMW’s Wi-Fi.
    The switched wire (the yellow one) has no impact on the RC6’s Wi-Fi.
    On my BMW K1600GT (2015), the top case connector includes a switched power supply (see https://forum.innovv.com/members/hans/photos/ — it’s the red/yellow wire).
    Regarding connecting to the app: are you using an Android device or an iPhone? iPhones sometimes struggle to connect to the app; if this happens, try putting your iPhone into airplane mode and connecting to the RC6 manually. In principle, you only need the app to configure the RC6 settings or to download videos—you don’t need it every time you start the RC6. Consequently, there is no need to maintain a constant Wi-Fi connection between the RC6 and your phone.
    Regarding the corrupted videos: are these from both the front and rear cameras, or just the rear one? Are they corrupted from the very beginning (i.e., from the moment the motorcycle is started), or do they become corrupted only after riding for a while?
    The fact that the blue LED flashes rapidly when the ignition is off (meaning there is no voltage on the yellow wire) indicates an issue with the power supply. Could you use a multimeter to check the battery voltage when the ignition is switched off?
    It is also possible that a faulty camera could cause issues across the entire system. If you disconnect the rear camera, does the RC6 then switch on and off correctly when power is applied to or removed from the yellow wire?
    • Frank
      2026-11-07 at 21:38
      Hi Hans,
      I checked the wiring and the voltages again and all is ok. The battery is fairly new. The voltage remains stable when yellow wire is disconnected.
      Following is the status:
      Automatic recording when yellow wire is in on state does not work anymore. All radar functions do. Ten seconds after as yellow wire goes in on state, the beep is there, both red indicators light up. The red warning lights indicate correctly when driving.
      I can do a manual recording by pushing the button on the front camera: it generates 30s videos in the accident folder, front camera only, this is strange by itself.
      The blue led rapid blinking starts after a couple of seconds after yellow wire is disconnected. I can only stop this by either disconnected the power of the control module or disconnected the rear radar/camera module. Disconnecting the front camera has no impact.
      My fear is that the rear camera is causing all these issues.
      On the corrupted files: both front a rear camera generate corrupted files at the same time.
      Files are too big to attach. I can always share some via google drive.
      • This reply was modified 2 weeks, 4 days ago by  Frank.
    2026-11-08 at 22:45
    Hi Frank,
    Pressing the button on the camera triggers a protected recording—essentially the same as an “accident” recording. In this case, a protected file should be saved from both the front and rear cameras, with the duration matching the setting you’ve configured in the app.
    All things considered, I strongly suspect a hardware fault in your system—likely in the rear camera, given the issues you’ve experienced with it previously.
    Feel free to send me a private message (PM) with a link to the corrupted files.
    I recommend contacting the seller of your RC6 to arrange for a replacement under warranty. Alternatively, if you are certain the issue is isolated to the rear camera, you could replace just that component. If you purchased the RC6 directly from Innovv, you can reach out to them via https://innovv.com/pages/contact
    I’d be interested to hear how this is resolved and what the final outcome is—specifically, whether the problem is indeed limited to the rear camera or if there is something else going on.
  • JAMES
    2026-11-09 at 23:18
    I have a similar issue with the blue light continually and rapidly flashing when powered off. Also have the fault on the radar indicators which work for a few mins then flash simultaneously for no reason. Have to disconnect rear camera to stop the distracting flashes. It worked for a couple of weeks and was very useful but I am frustrated now.
    • Frank
      2026-11-10 at 03:44
      I had that once and was probably the lead in to the problems I am experiencing now. I am working with Innovv support who are very helpful. Will report on progress.
