Forums › Forums › N2 › Shock sensitivity settings?
  • N2
    Posted by Charles on 2026-01-30 at 12:58
    Even on the lowest setting, my N2 saves files when im just riding on city streets. I’ve turned the g force off because I have to unsaved 30 or 40 files everytime I ride on pavement and Im worried my memory will get full on multi-day trips…. Anyone else having this issue? With the g force turned off, I then worry if I crash or get hit, the video won’t automatically save…. Any thoughts?
    Hans replied 8 months, 3 weeks ago 2 Members · 1 Reply
  • 1 Reply
    2026-02-01 at 18:27
    Hi Charles,
    Is there any way to mount the N2 differently? Or is there a way to place a rubber ring between the mounting points for dampen the vibrations?
    If the G-sensor is disabled and you crash or get hit while riding, this will be saved as a regular recording. Assuming you won’t be riding again after a crash, the recording won’t be overwritten. If you do start riding again, you’ll have to manually save the video before it’s overwritten.
