Hi Cameron,
I think this is only intended for data transfer and not to power the N2. I don’t have an N2 myself, so unfortunately I can’t test it myself.
But if the N2 can be powered by USB, you’ll need a power supply that can provide sufficient power.
If you manage to power the N2 via USB, please let me know.-
Thanks for the reply, Hans. I tried powering it with a suitable battery which displayed that it was outputting 9.9v, but the unit didn’t power on. Having said that, I haven’t updated the firmware yet. So, I’ll powering it up with the bike battery first and get it updated.
Hello, you can power the N2 using a USB port on your motorcycle,
but only if that USB port provides enough power(typically 5V/2A or more), and only for basic functions like CarPlay.
We advice to power the N2 using its dedicated 12V power input, not just USB.
If using USB power, water ingress into the data port and memory card slot may damage the device. Therefore, avoid using USB power while riding in rainy weather.
The USB port of N2 is for debugging software and can be used for power supply, but it cannot be plugged into a computer to transfer data.
Hi Innovv,
Thanks for the info. This clarifies the USB port.
I assume the same applies to the N1?-
Hello Hans, the N1 does not have a USB port, while the N1 Pro has a USB TypeC port. Yes, the properties are the same.
My N2 won’t power up via usb-c, yes the power source is supplying enough volts, amps.
Hi Adam,
Are you able to power other devices with your power source?
Do you have the option to test with a different power source? This is to rule out the power source as the cause of the problem.
When using the USB connection, have you disconnected the N2 from the power supply coming from your motorcycle?-
i had this issue too. and I found the solution.
If i use a USB-C to USB-C cable then my N2 powers up
If i use various USB-A to USB-C cables then it doesn’t-
Hi Mark,
Are you using the same power supply each time you try a different USB cable? Some power supplies are not recognized by Innovv cameras. In my experience, this tends to happen with power supplies that have a higher power output.
interesting. i have retested usb-a to usb-c and i can power the n2 from a battery pack, a laptop and a usb wall charger today.
yesterdays issue is completely unexplainable….!
Hi Mark,
You haven’t changed anything else in the configuration, have you? For instance, you didn’t disconnect any cameras, did you? Or perhaps use a different cable?
The n2 is currently inside the house and I don’t own the GPS or camera modules (yet). Cannot explain why the usb wouldn’t power one day, but now is consistently fine. Kinda odd, but I consider my issue resolved!
I think I haven’t cracked the amswer to the problem.
Running the device from my power pack is intermittent.
Running from a 60W laptop usb c charger doesn’t work
Running from a laptop port with usb c to usb c cable always works.
Usb A-C sometimes works sometimes doesn’t. I haven’t identified the pattern yet.
