Forums › Forums › K6 Dashcam › WIFI
  • WIFI
    Posted by Nicholas on 2026-03-26 at 17:21
    Hello to all,
    hoping I am not duplicating any other posts, I would like to ask you the difference in setting up the timing for the WIFI on.
    what is the difference between having it always ON or OFF after few minutes (depending the setting)?
    If the WIFI goes OFF (due to the setting imposed) is there a way to switch it back ON with the button?
    Thanks in advance
    Nicholas replied 7 months ago 2 Members · 2 Replies
  • 2 Replies
    2026-03-26 at 18:02
    With this setting, you can specify after how many minutes the K6’s Wi-Fi module is switched off. When Wi-Fi is turned off, the Wi-Fi connection to your phone is lost, and your phone can then connect to other networks.
    If you power the K6 with a power bank, this will provide a small energy saving when Wi-Fi is off.
    You can switch Wi-Fi back on by pressing the button twice in quick succession.
  • Nicholas
    2026-03-26 at 18:04
    thanks a lot…all clear 🙂
