Forums › Forums › K7 Dashcam › WiFi Hot spot not turning off
  • WiFi Hot spot not turning off
    Posted by yoda on 2025-07-22 at 01:09
    Even if my k7 is configured to STOP broadcasting a WiFi hotspot after (x) seconds, it stays on all the time… I don’t want a HotSpot broadcasting my but during hours 🙂
    Hans replied 1 year, 3 months ago 2 Members · 3 Replies
  • 3 Replies
    2025-07-22 at 01:14
    Hi Jeff,
    Does the Wi-Fi LED stay on then?
    What if you set a different timeout?
    You could try reloading the firmware.
    • yoda
      2025-07-22 at 01:19
      yes the WiFi led stays on. I played with different time settings etc
      Will try installing most recent firmware.
      Question : if I use a 64 GB SDCARD to update the firmware and format it with a 32 BG partition, will the k7 recognize it ?
      I don’t have a 32 GB or lower one… as required.
      • This reply was modified 1 year, 3 months ago by  yoda.
      2025-07-22 at 23:21
      Hi Jeff,
      It’s best to format the SD card in the K7. I think the firmware update should work with a 64 GB drive. But it’s a matter of trial and error.
