Yellow wire, no cameras
Hi, I’ve just received my new N3 system without the cameras (no use for it) and want to go install it now. I’ve read that the yellow wire is actually the on/off wire for the system and should be connected to another item that gets power when turning the ignition. Does this also apply when not having any cameras or can I just connect it to the red wire and straight on to the battery. Or wil it drain the battery even when disconnecting the unit from the cradle?
Thanks for you help guys!
This discussion was modified 4 months, 1 week ago by
Jeroen.
