Forums Forums K3 Dashcam Station mode
  • Station mode
    Posted by Michael on 2024-08-30 at 19:57
    Is there a button press combination of HTTP request I can make to the device to get it to work in station mode? I’d like to access some sort of network file share or at least the web dashboard from my home wifi network rather than the device itself.
    Or if there’s any experimental firmware to try I’m already out of warranty so i’d be happy to try that too.
    Frostie replied 8 months, 2 weeks ago 3 Members · 3 Replies
  • 3 Replies
    2024-08-30 at 20:05
    Hi Michael,
    I think you can try the same thing with the K3 that is mentioned in this K5 topic.
    The point remains that you have to activate the yellow wire somehow to wake up the K3.
    https://forum.innovv.com/forums/discussion/k5-open-ports-ways-of-connection/#post-2819
    • Michael
      2024-08-30 at 20:18
      Hi Hans,
      The core issue / query here is changing the the device to connect to an existing WiFi network, not having the device act as an access point which is it’s default behaviour.
      I appreciate your commands list that you have discovered but the web interface comment was more for context.
      I know of at least one other Novatek SoC based Dashcam that supports this feature and was hoping someone could chime in this device specifically.
  • Frostie
    2024-09-26 at 15:40
    Hi Michael,
    late reply, as I was out or order for some weeks due to a surgery.
    For the K2 I did a modified firmware which connected to my home wifi. And as the K3 and K2 share the same base hard- and firmware, this should be possible at the K3, too. But it was more a proof-of-concept than a good running solution. The SSID and password needed to be hardcoded into the firmware. Additionally, the firmware does not allow long and/or complex passwords, which means your home wifi needs to use an easy short password. Not recommendable. And finally, the modified firmware will not allow the use of the Innovv app anymore, as it is not possible to switch back to AP Mode. For reasons I don’t know it did not work to switch from Station Mode to AP Mode with the modified firmware. The AP did not accept any clients then. Of course one could re-install the original firmware to get everything back working.
    If you are able to suffer, you can try your luck by temporarily switching the K3 to station mode. At the K2 it was possible to use some http commands to temporarily switch it to station mode. These settings are not saved, so at next reboot it switches back to AP Mode. But I never tested this on the K3.
    Set SSID and Password:
    http://192.168.1.254/?custom=1&cmd=3032&str=SSID:PASSWORD
    Set Wifi to Station Mode
    http://192.168.1.254/?custom=1&cmd=3033%par=1
    Restart Wifi
    http://192.168.1.254/?custom=1&cmd=3018
    • This reply was modified 8 months, 2 weeks ago by  Frostie.
