Can I Use a Car Dashcam As a Motorcycle Dashcam?
As a motorcycle rider, you may wonder why motorcycle dashcams are so much more expensive than car dashcams, even though they both serve the same purpose. You may be tempted to install a car dashcam on your bike to save money, but this is not a good idea. There are some important differences between motorcycle dashcams and car dashcams that you should know before you make a decision.
1.Space and wiring: Motorcycle dashcams have to fit in a smaller and tighter space than car dashcams. They also have to deal with wiring. This means that finding a suitable installation spot for a car dashcam on a bike can be very difficult.
2. Waterproofing: Motorcycle dashcams are exposed to the weather, unlike car dashcams that are protected inside the vehicle. Therefore, motorcycle dashcams need to be waterproof and durable, usually with an IP67 rating or higher. Car dashcams do not have such a high requirement for waterproofing.
3. Interference: Motorcycle dashcams have two separate cables for the front and rear cameras. These cables are very sensitive and can be affected by the engine, heat, or other sources of interference, causing the device to malfunction. Moreover, the motorcycle dashcam DVR and cameras need to have anti-interference technology to prevent this problem. Car dashcams do not have to deal with such issues.
So, if you think you can handle these problems and have enough time to maintain your device, you can try to DIY a car dashcam on your bike. However, I strongly recommend that you choose a dashcam system that is designed for motorcycles, according to your needs and budget.
INNOVV is a leading motorcycle brand that offers the world first 4K motorcycle dashcam K5. As well as the easy-to-install, 2K + 1080p camera system, K6. I think you will find the right one for you among their products.
Responses
