Systematic end-of-file recorded video missing / dropping 8–10s of footage
I am seeing a 100% reproducible issue with the K7 (latest firmware IK7.20250317.V05) where, after 4–8 minutes of riding, one pair of recordings (front+rear) is missing the final 8–10 seconds of video. The subsequent file pair starts on time, meaning there is a permanent gap in the timeline.
This happens 100% of trips for me – does it for you? Note this is very subtle, you won’t notice unless you pay close attention to the recording file durations (or size). If you have a K7, can you please check: every recording should be around the same size, 106.5MB for a 1-minute interval. Somewhere around the 4th to 8th pairs of front+rear, one pair will will be shorter by 5-10s, or about 90MB in size.
TBC, it’s only the final 8-10s that’s missing from the end, I’ve never seen a recording cut at the start or in the middle of a file.
I’ve been going back and forth with INNOVV support on this, and specifically have asked them if they’ve been able to reproduce the issue (given it’s 100% reproducible for me). They have avoided answering that, instead suggesting everything _except_ the dashcam could be an issue, e.g “it’s the card”, or power supply related. Yet I’ve eliminated the card – issue occurs identically across four SD Cards, from two different manufacturers (3 x SanDisk Endurance and a no-name, all U3 rated and all work fine in terms of no issues on any other file); formatted by the app or not. And the main power supply is directly to the battery; moreover the issue only occurs at the end of a file recording, and correctly starts a new recording at the next 1 minute interval.
If you’ve seen this issue, it would be worth reporting as it may motivate INNOV to look into it and even fix it.
NOTE: I believe this is unrelated to the SD Card / power issues discussed in the “K7 randomly stops recording and restarts recording during rides”; the key difference being only one file pair is truncated, only at the end, and no halt/etc occurs.
This discussion was modified 9 months, 4 weeks ago by
Ben.
