MAGUGULAT KAYO SA QUALITY NITONG CAMERA ll INNOVV K6 MOTORCYCLE DASHCAM (VIDEO)
*Below video is from Naj Abdul. Please kindly click here to visit his YouTube channel.
The INNOVV K6 dashcam is with 2 cameras in the front and rear of the Motorcycle, The wide-angle cameras help to capture most of the views during the trip.
【2K Quad HD Resolution】Dual Camera System with 2K @ 30FPS Front Resolution & 1080P @ 30FPS Rear Resolution.
【Aluminum Alloy Construction】The K6 dashcam’s aluminum alloy housing has a sleek metal texture and is expertly machined with a digital CNC lathe for excellent heat dispersion. It can withstand extreme outdoor temperatures from -22F to 128F (-30C to 70C).
【Stylish Appearance & IP67 Waterproof】IP67 rate, superior performance against water, and dust, and excellent performance in high & low-temperature environments.
【F2.0 Aperture and 140° Wide View Angle】The F2.0 aperture and 140° wide viewing angle of the INNOVV K6 dash cam provides a wider range of view, allowing you to capture more of your surroundings.
【Fully Featured Innovv App】With built-in Wi-Fi connect & APP control feature, you can easily access and manage your dashcam footage through your phone.
Responses
