INNOVV K2 Motorcycle Dashcam Installed on Honda Goldwing/Panther Trike
INNOVV K2 motorcycle dashcam installed on Honda Goldwing/ Panther Trike. Below are a few pics.
The DVR fits nicely in the top box using the foam packaging slightly modified to hold & protect the unit.
Related Articles
INNOVV K1 Motorcycle DashcamSystem Installation on 2008 Goldwing
My goals in mounting INNOVV K1 motorcycle dashcam system were to have easy access to the memory card and the trigger button to save video segments. I also wanted to minimize any interference the wiring would present during disassembly of the bike for servicing (removing plastic panels, etc.). My starting point was the following video, which places the recorder in the rear top case.
MO Tested: INNOVV K3 Motorcycle Dashcam Review
Back in 2016, I reviewed the INNOVV K1 dashcam and really liked it with one exception, a lack of weatherproofing. Next, we tested theINNOVV K2, finding it much improved. Well, the INNOVV K3 motorcycle dashcam is here, and it has reached what I consider to be peak functionality as a motorcycle dashcam. Regular commuters in urban areas should consider this as an option to use to protect yourself from false claims in the case of a mishap.
K2 Motorcycle Dashcam install on a 2018 Harley Ultra Limited (FLHTK)
A few words and pics of a K2 motorcycle dashcam install on my 2018 Harley Ultra Limited (FLHTK).
With pre-planning install was fairly straight forward, the only major components I had to remove were the front fairing, tank, seat and left side bag.
Don’t get too freaked out about the tank removal, it’s really not that difficult, just 6 bolts, 1 screw, a plug, drain hose and a quick release fitting … a tip, the less fuel you have in the tank the lighter it is.
Also I did partially pop the wiring chase under the tank to ensure the wires weren’t pinched when routing, it’s an easy opening, just some plastic tabs to release.
Responses
